Main Crank- Repair of vibration damper?
cblue
89 Bronco- 5.8L
I removed the front end of engine to repair main seal. Using the puller, I removed the vibration damper from the spline section. I tried to push back in but bent my 12T press pins. Can this be fixed or do I need to get another vibration damper?
I would highly suggest replacing the harmonic balancer if it's damaged in any way. JSM84
Motormouth2025
