Low idle when turnign steering wheel.
With those big tires on it, you are probably loading down the steering pump which in turn loads down the engine. The stock Ford steering pump isn't too well suited to oversized tires. Your best bet is a Saginaw pump conversion. You can get one from an E250 with the same engine as you have. You will need the pump, brackets and high pressure hose. From there it is a no brainer.
seansz28
