low gearing and gas mileage
lady_tigger
Her Toy and Loving it
Phoenix Arizona
Is there any way to improve the gas mileage on my truck? I have a 351 and get about 8 miles to a gallon. I Know that it is geared really really low but I dont want to change that. I was told bigger tires but that would lead to another question about lift kits. Any suggestions. And if a lift kit is necessary what is the cheapest and safest way to lift 3"? And then what do i do about the width of the rim Right now I am running 31" 10.5s. Would have to go up in size on the rims but afraid they are going to rub the fender wells? HELLLLLLPPPPP?
jtp1201
amarillo tx
18716[/snapback]
first off do you have and overdrive tranny? if not then you could step up to taller tires and that will do the trick somewhat. as far as a lift the simpliest and cheapest is a body lift average cost is 150.00 really simple to install. keep the current rim size those are wide enough
highrider
i have a 351 in mine as well and its brand new i get about 8mpg and i have 35s bigger tires wont make it better so relax and if u want more lift for a small price go body it wont affect ur suspension and ur rims u have now will be fine.
Wihill
