loses power on hills
Pony-boy
That's not a dent, It's a gift from the t
Roy, WA
The reason why I say it was not a fuel problem is because you stated yourself that the RPM's stayed the same and the speedo
dropped 10 mph. If you had a fuel problem it would drop the RPM at the same time.
I may be wrong but I think when you pull the diff cover you will probally
see that the clutches or spiders are letting go. Check the ears on the clutches to see if they are still there. Sounds like they are either broken or spooling up and causing the rear end to bog down.
Good luck
The more I read this thread, I believe Pony-boy is on to something!!! I had a Ford8.8" rear axle go out on me, with no prior warning. IT started growling really bad all of a sudden, and 2 miles later needed a tow truck. I would certainly pull the rear cover off and inspect the gears and the fluid for metal particles, as those pics look just like mine did. All of the fluid burned up due to the excess heat!
Pony-boy
Roy, WA
Do yourself a favor. Seriously
If it is to cold or rainy in your area to pull the cover,
This will take 5 minutes at most.
Get under your rig and pull the filler plug from the rear end.
It is located at the front of the diff and the drivers side of the pinion.
It has a magnet on the end of it. If you do that, there should be
little to no metal particles on it and the gear oil should
smell rancid :-& but not like burnt toast.
If you wannt take it a step farther.
Get a white paper towel or piece of clear white paper would be better.
Stick your finger in the hole and drip the gear oil on the paper.
It should look like the color of motor oil or maple syrup.
If it is grey, metallic or very dark. You have a problem and need to quit
driving it until it is fixed, because it will most likely leave you stranded.
J
jaszon
rhode island
it is cold and snow on the way but im definately going to get under there this weekend,im trying to find out what gear oil i need,right now i have some left over but unopened 80w-90 gl-5 but i think i need hypnoid right or is it the same.i know i need 4 oz of additive to.
J
jaszon
rhode island
HELP....ok i found some metal filings now what do i do :(( .....i heard its pretty expensive to rebuild the rear end and i just dont have that kinda money,things are tight.it is a little low on fluid,do you think that could be why im seeing the filings or am i in for it.
J
jaszon
rhode island
i just checked and i dont have limited slip so i added the appropriate fluid and the rear differential was a quart low :unsure: ,its now 11:48 at night and 15 degrees so thats all i can do for now.
DragonDave
The OC SoCal
I'm gonna be servicing mine soon................Hope I don't find no chunks! :unsure: Im gonna do some synthetic gear oil.
J
jaszon
rhode island
the weird thing was they werent chunks they were fine sparkles,i wiped the stuff i found onto paper and used a magnet to pick the stuff up and it was finer than sand,some a little,i mean little bigger but nothing like a chunk.
When it warms up or first chance you get, pull the rear cover and take a look inside the diff. at the gears and bearings.
Pony-boy
Roy, WA
Your carrier bearings are probally going out. Or your
pinion bearing.
You are lucky that you don't have the L/S diff though.
The open carrier is much stronger and is probally what it is still
together.
Try to find someone, friend of a friend, that can do gears.
The gears themselves are pretty cheap. $120 to $150 for a R&P
and about $100 for a shim and bearing rebuild kit. When you can
pull the cover you will know if you need new gears or not. You
could get away with not having to replace them if it is only the bearings.
Shoot maybe someone on here that is close could help.
Start pricing both the gears and the master install kits so you know
what you need to spend on that.
Genuine gear from 4WP are the low budget way to go and they sometimes come with the kit.
If you are not really ******* them they are a good replacement R&P to
go with.
Don't listen to the flaming about to happen with 4WP. Lots of
people don't like them. But you need a SMALL Budget rearend and
they are the place to go.
I am sorry that you now need to spend more money but I am glad you
found out what is in store before it really broke.
J
jaszon
rhode island
today i had about 20 min to work on truck so i pulled the rear speed sensor that is magnetized and there wasnt one metal particle on it,i even wiped it with tissue to be sure.i still plan on opening it up but the weather only allows so much.if this isnt the problem were else can i start looking.maybe the o2 sensor?
J
jaszon
rhode island
i think i got it......the transmission filter was the original with 110,000 miles on it.i changed the filter and added tranny fluid then took her for a spin and she drove with alot more pep and power.tommorow ill try to see if she acts up on hills.i hope this was it,now i have to tackle the leaking oil pan gasket.the original owner didnt believe in preventitve maintenance i guess or just plain lazy.it even had the original fuel filter but i did get receipts for the oil changes thank god for that. thanks everone for the help and ill try to update wit hmy progress.
