lever on auto trans not connected
scroller bill
Hi all. Vehicle info in signature, not sure what auto trans I have.
My question is on driversside of my auto trans,same place shift linkage goes into trans, there is an arm that does not have anything connected to it. Opposite end of arm has a round shaft with a c clip on it. The arm pivots downward. Can someone tell me what this arm is for?
Two pictures are attached. Hard to get good pic because driveshaft is in the way. arrows are pointing to it.
Thanks, Bill
P.S. I think i screwed up on picture size, If they are too big, let me know.
Picture size just fine Bill, please only post once per question. If you need to change anything you can edit the original post. See response above.
PS, that is definately the attachment point for the kick down rod.
S
scroller bill
Thanks seabronc. So your saying that I screwed up by making a second post with smaller pics of a previous post. Sorry for that. I definately do not want to p**s anyone off, not this forum and definately not you seabronc. Of the 3 bronco forums i have signed up on, this one and more directly you have helped me the most. I'm new to this kind of restoration of a vehicle. I have learned so much from you and I know that with your help this restoration will get done and done right.
Thanks again. Bill
P.S. You weren't kidding when you said that the fsb forum is rough on newbies. You realy have to do your research before asking a question. I didn't ask anything, just broused the posts.
Motormouth2025
