Just joined!
TennesseeBroncBoy
Fort Walton Beach, FL
I just bought a 93 4X4 5.7 stock Eddie Bauer Full size. I wish it were not an automatic, but when you move to Iceland(current location) and only have 3 weeks to find a nice Bronco for under 5k, you kinda take what you can get. I need to fix some stuff and it looks like this place is the place to be for most all my questions. Future Projects: Fix ABS that doesn't work <_< , cluster lights that go off when I pull the headlights **** all the wayout :mad: . Lift kits 6" suspension and 2-3" body. 38" tires, new front end gears. Glad to be here! See you soon. COWBOY UP! <)
Welcome to the Zone > . That problem with the lights is most likely the switch. Sounds like you have some fun lined up :D/ . Post some pictures :-B .
TennesseeBroncBoy
TennesseeBroncBoy
Thanks for the info. Calling BroncoGraveyard in the next couple of days. Here in Iceland the sun doesn't ever go down till the end of the year. I have time to get it fixed, so I'm not in too bad of shape. Thanks for the info. Any tips on how to get in there(Under Dash) to replace it? Also, did anyone see my other post about ABS brakes not working? (I have computer code read-outs)
Welcome to Bronco Zone!!!
I posted in your ABS thread, looks like the problem may lie with those sensors. Good luck with the headlight switch, once you figure out the mounting it's easy to change.
TX_BEAST
waxahachie texas
welcome friend, i got tot ask do you have a chevy motor in there [-X or is it the 5.8 liter ford motor [-o< .
TennesseeBroncBoy
TennesseeBroncBoy
3 or 4 of my buddies all have Bonco's here. There are a few locals who have bought them from the Americans here as well. So I see them on base all the time, but not too much other than that. They usually buy the F-250's and F-350's, due to a lower import tax. Engine size in those are classified as a work engine and are cheaper to import. Same with the 351W.
bluesman17
Spam Terminator
South Bend, Indiana
To replace the headlight switch you have to take part of the dash off, remove the two trim strips on the main console part (black with speedo and gauges in it) youll have to have something to push on the clip that holds the **** on the switch (looks like this and fits in a groove _/__). Good luck!
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
2K
T
T
Replies
Views
1K
T
Oldhenry1
