Just bought a 1984 Bronco for my summer project, this is my "learn to do" experiment this summer seeing I have little experience with vehicle maintenance. So a run down on what I bought
1984 Bronco
302 5.0L
C6 Transmission
70K miles
This guy runs great and the transmission is in great shape. The brakes however, are pretty much not there. I replaced the brake booster, and am about to replace the calipers and brake pads this weekend in hopes it will fix it. Tailgate window has a problem with the regulator arm on one side being bent back, and it slips out of the "slider"? Also The exhaust system is gone, it is cut off after the Y-Pipe. I brought it to a mechanic to look at the carburator because it needs a lot of gas to start up, and while warming up, I have to keep my foot on the pedal for a couple minutes. He said there was no issue, but even while driving away, when accelerating from a stop I push the gas down and it feels like it takes a second or two to get gas delivered. I plan on making quite a few repairs this summer, I just want to know if there are any tips out there for the existing problems? and maybe some tips for me for improving it all around, some must dos!? I've played with the idea of ordering a crate turn-key engine and installing it, so any comments on that would be great.
Also what can I do to get this running up to 14-15 mpgs? would ordering a newer engine do that?
What type of custom engines could I put into it?
What type of upgraded transmissions could I put into it?
1984 Bronco
302 5.0L
C6 Transmission
70K miles
