yo;
Walker Dimensions & Depiction; Including Heavy Duty Aluminized Part #22382 for 80-96 Bronco & F Series;
INLET ID is 2-1/4",
OD is 2-1/2" Same for OUTLET; see Table 3, Style 2-OFFSET TO OFFSET; Overall Length is 30"; Shell Length is 24"; Cross Section is 6"
Source: by walkerheavyduty.com
http://www.walkerheavyduty.com/catalog/docs/WHD08_Arc_Welded_HD_Mufflers.pdf
The K&N does away w/the "cold" air intake tubing that runs from da Filter Box to top of radiator... not so "hot" an idea..
I like this better, using Ford Motorcraft Air Filter and changing it yearly or when after running thru the dust bowl/getting it soaked in floods..etc.;
Air Tube & Box Insulation pics in a 94 5.0; Ken used Reflectix Insulation, avail @ Lowes. etc. ST16025 - 16" x 25 feet. miesk5 Note; Ken installed the K&N® & removed da cold air intake tube that runs to the top of the radiator; but he could have installed the intake tube section later.
Source: by Ken B (Kenny's 94) at
http://www.supermotors.org/clubs/superford/vehicles/registry/detail.php?id=9319&s=29460#content
You'll need the Conversion Kit ONLY if you have the 3 ***** Cover on the auto hubs.
see my site for installation Links
http://www.broncolinks.com/index.php?index=107
3 ***** to Superwinch™ in a 93 w/ Bearing Locknut Torque Settings & tool list
Source: by Froggmann (Ken P) at
http://www.froggmann.com/Bronco/Tech/3boltconv.htm
especially,
5 ***** to Warn® & Bearing Replacement w/ Bearing Locknut Torque Settings in a 90;
Look at the diagrams, intall & operating info by Warn®
and,after you get the manual Hubs of any Brand and ready to Torque....
Wheel Bearing Locknut Torque Settings for
80-96 MANUAL HUBS, NOT Factory Auto Hubs; Ford Pickups and Bronco; "...Using a lockout spanner (ford # T59T-1197-B or equivalent get or borrow at a parts store) and a torque wrench, tighten the inner bearing adjusting nut to 50 foot pounds while rotating the wheel back and forth and seating the bearing. Back off the adjusting nut approximately 45 degrees. Assemble the lock washer by turning the inner lockout to align the pin with the nearest hole in the lock washer. To lock it, install the outer lock nut and tighten it to 150 foot pounds. Grab the top of the tire with one hand and the bottom of the tire with the other. Move the tire in and out on the spindle. End play should be less than .006 – inch.).." Thanks to 90beater (Topher, Chris)!!!!
Source: by 90beater (Topher, Chris) at bronco.tophersworld.com
http://bronco.tophersworld.com/writeup_hubs.htm
GL
