its been so long...
vincendebbie
vincendebbie
Covington, La.
whats the best way, its been a while!
Fill up the master cylinder and remove plugs from outputs and allow the fluid to gravity feed. Or if you have a suringe with a rubber tip you can place that over each output and **** the air out. Hope this helps. --Vince
BB33's
Rancho Cucamonga CA
They sell bench bleeding kits at autozone( or whatever parts house is in your area) all it is is two pastic ******* that ***** in to your brake line holes and two short plastic tubes that go up to your fluid resivior. just filll the resivoir with fluid and use a phillips screwdriver to actuate the valve and do it until nothing but solid fluid comes out
seansz28
