Is there a tool?
Lump1713
Hey guys, I need help. I went to go give my truck an oil change and I found out the previous owner had stripped the oil drain plug. Is there a special tool to use to get the stripped drain plug out? I tried everything to get it off but seems it keeps on stripping. Help Me!!!
KJEfting
Ogden, Utah
You could weld a new bolt to the head of the stripped plug and then turn them both out.
have you tried Vise- Grips??? If the bolt head is rounded off, these clamping pliers may work. If not, I would be afraid of welding on the oil pan due to possible fire, but glueing a good nut on top with JB Weld should work. IF the bolt is stripped inside of the pan and just turns, use a screwdriver for leverage while turning the Vise-grips or the bolt. Many oil change outlets will tighten hella out of the oil pan nut, and then they strip out. Once removed, you can use a larger-size bolt/plug. Think there's a previous post on that topic, too. JSM84
L
Lump1713
Tack weld a thick rod onto the plug. This will give you something to get your fingers on while turning by hand & pulling at the same time.
Torque with a small crescent if need be.
I tried Vise grips too. they dont work either... I may try glueing a good nut on with jbweld. I'm skeptical about welding it myself. I will have to try that and see what happens...
Naw,
Tack welding (wire-feed) 4 l'il spots wouldn't hirt a thing.
Of course, things should be clean & dry.
(& assuming there's no "gas" in the oil)
Total arc time would be 1-2 seconds.
bidibronco
Norfolk Va
I had this problem one time before but it wasn't with the Bronco. What I did was tighten some vise grips real tight to pute the little teeth groves into the nut. After that I took it off and used some decent sized channel locks and some "brute strength" and it came out. :wacko:
firelt90bronco
Ask me about my job
northeast
What about a damaged bolt remover like the craftsman bolt-out? The Vise Grips should do it, but you should hope that the threads on the oil pan itself are still good.
404PageNotFound
Raleigh, NC
do it the lazy man's way... just replace the oil pan entirely :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
you could use an EZ-OUT (spelling?)
eholt80
