No difference, the shafts are identicalIs there a difference in driveshafts 78-79 if there is can I make it work
No, there isn't. BOTH the 78' & the 79' have the double cardan shafts, please see the pages I scanned from the *1978* factory manual. Just what kind of driveshaft do you think a 78' has ? 1978 E100-E350, F100-F350 & P600 trucks were sometimes equiped with a single snap ring type Ujoint, depending on wether it was a long or shortbed truck but the *only* driveshaft offered with 78' & 79' Broncos was the double cardan and that's because of the short wheelbase, the longer wheelbase pickups could use the single snap ring but NOT the Broncos. I'll scan the pages if you need to see them.there IS a differencethe 79 has the double cardon shaft
ok ok I was wrong about the cardon part but, they are different the yokes on the 79's and some very late 78's are larger
