BentSpurs
I have a salvage 4WABS HCU to install in our ‘96 Bronco EB that the ABS warning light has been on for a few months. Is there a procedure for bench testing it before installation?
Thanks!
Thanks!
Miesk5,Yo Bent,
4WABS Hydraulic Control Unit (HCU) & Valves Wiring Diagram & Overview; "...The front inlet valves should read 5-8 Ohms each; all other valves should read 3-6 Ohms each. Sensors should read 800-1400 Ohms across the pins, and more than 10 Ohms from the metal shell to either pin. The pump motor sensor should be 5-40 Ohms. The acceleration sensor is a group of switches which should be closed when the truck is stationary & level. When the sensor is tilted ~1" up in the rear, pins 2-3 should go open; when tilted ~1.5" up in the front, pins 1-3 should go open..."; miesk5 Note; for all Resistance tests, battery needs to be disconnected; remove Negative cable at battery.
Yo Paul,Bent
If you could do a detailed write up of the repair ... I would be greatful... my ABS light has also just came on. I'm on the fence about just getting a porportioning vlaue and bypassing the whole ABS system.
Yo B,Update: 4WABS HCU from a salvage yard arrived. Luckily had a master mechanic friend who bench tested it. Fail, open circuit.
So what year, model Explorers have compatible ones?
Thanks!
Yo,Thanks very much Miesk5. I've sourced a '94 Explorer 4WABS unit so we shall see if it bench tests before doing the Franken-pump surgery. BTW, have you ever heard of anyone rebuilding one of these? Some old school starter rebuilders should have the skills.
Cheers!
Bent
Tiha's comment above gave me pause re prospects for rebuilding or at least for a reasonable amount of money vs other routes. I'm fairly certain that BBA has tubed based on recent comments I was seeing from owner's who'd sent units for rebuild and having no luck getting anyone at BBA on the phone or to reply to emails. Too bad, they were doing well but apparently went into receivership, aka O thank heaven for Chapter 11 (or 7). It mystifies me as to why no one is making a 4WABS HCU given millions of F-series not to mention Broncos as a ready market especially in today's world where more and more of them are being restored. Now where did I put that phone number for Warren Buffett? Thanks!Yo,
Last year I checked Cardone on line catalog and they showed it as available.
I then checked Rock Auto and they list 122025, but describe it as "w/Rear Wheel ABS Only" .
I called a Navy pal who works at Cardone and asked him about 122025.
He confirmed with his technical group that 12-2025 is for JUST Rear Wheel ABS, NOT 4WABS.
NEXT UP TO BAT is BBA which was WELL-REGARDED for their remanufactured 4WABS control modules and HCUs. http://www.bba-reman.com/us/catalogue/parts/84/
Following from August 2020;
4WABS Hydraulic Control Unit (HCU) Sources "...Used price locally is $150.00; 60 day guarantee; Babaganoosh wrote; "...BBA did the rebuilds on ABS Modules for my old VW/Audi Shop. They were super inexpensive, fast, friendly, and only had one issue with them ever and it was 50% my fault anyways (keep in mind it's VW stuff anyways...". by consensus the best re man 4WABS Hydraulic Control Unit (HCU)s are from bba-reman.com; BBA quotes $200 plus shipping for repair of/my HCU; "It usually takes about 3 days from receipt to repair..."
miesk5 UPDATE, check w/BBA first; they may have stopped re-man ops.
Yo, try this Google search:Tiha's comment above gave me pause re prospects for rebuilding or at least for a reasonable amount of money vs other routes. I'm fairly certain that BBA has tubed based on recent comments I was seeing from owner's who'd sent units for rebuild and having no luck getting anyone at BBA on the phone or to reply to emails. Too bad, they were doing well but apparently went into receivership, aka O thank heaven for Chapter 11 (or 7). It mystifies me as to why no one is making a 4WABS HCU given millions of F-series not to mention Broncos as a ready market especially in today's world where more and more of them are being restored. Now where did I put that phone number for Warren Buffett? Thanks!
Yo,Was just about to pack up and ship the nonfx 4WABS back to the junk yard for swap to Explorer and thought, WTH one last try at an online search for repair, rebuild services and had a few hits but after I'd call to discuss, would find they only worked on the electronic modules, not anything hydraulic. Then stumbled upon "ECU Testing" (Heanor, UK) who it appeared actually work on HCU units so I called them and spoke w "David" who in his proper accent assured me that while they hadn't rebuilt my exact part (their website shows they have done a variety of Ford model parts), it sounded doable and to send it and pointed me to their webpage w the "Test Form" where I could submit all the pertinent details and it would generate my DHL shipping label. And it did without so much as a credit card. They'll bill me when the rebuild is complete, around $50 shipping and between $230-270 for the rebuild which is 2-3 days turnaround. Dropped it off at a DHL location today. Granted, this is as much an experiment to see if this is as a legit service as their FB reviews would indicate but that is the latest. Stay tuned.
Miesk5,Yo,
4WABS Hydraulic Control Unit (HCU) Bleeding Procedure (DIY)
Source: by SigEpBlue (Steve) at FSB
Also see 96 Bleeding @ http://www.diesel-dave.com/vehic/manual/stj/stj66021.htm
Is their or do they not have any hydraulic shops in your area. ? If so. They could look at it and tell you if and what parts they have to fix it.Was just about to pack up and ship the nonfx 4WABS back to the junk yard for swap to Explorer and thought, WTH one last try at an online search for repair, rebuild services and had a few hits but after I'd call to discuss, would find they only worked on the electronic modules, not anything hydraulic. Then stumbled upon "ECU Testing" (Heanor, UK) who it appeared actually work on HCU units so I called them and spoke w "David" who in his proper accent assured me that while they hadn't rebuilt my exact part (their website shows they have done a variety of Ford model parts), it sounded doable and to send it and pointed me to their webpage w the "Test Form" where I could submit all the pertinent details and it would generate my DHL shipping label. And it did without so much as a credit card. They'll bill me when the rebuild is complete, around $50 shipping and between $230-270 for the rebuild which is 2-3 days turnaround. Dropped it off at a DHL location today. Granted, this is as much an experiment to see if this is as a legit service as their FB reviews would indicate but that is the latest. Stay tuned.
I called 2 hydraulic shop hear and they DID NOT work on them and the DID NOT know anyone who does. SorryIs their or do they not have any hydraulic shops in your area. ? If so. They could look at it and tell you if and what parts they have to fix it.
