Is it just too cold to start?
BBroker72
Chattanooga, TN
I just recently bought 1972 Bronco with a 5.0 Fuel Injected engine. I have tested the alternator and battery and they both are good but the engine still doesn't want to crank in the morning. I live in Chattanooga, TN and typically it isn't much colder than say mid to high 20's. Am I missing something? Why won't she crank up?
Is there anything I can do to solve this problem?
Any help is appreciated.
BBroker72
kschirman
Kent, WA
What type of battery is in it? When you tested the battery was it when it was cold out or later in the day when it warmed up?
Hi Broker., welcome...
Could you be more specific/more info...? :unsure:
"...still doesn't want to crank in the morning."
To some this (crank) means., spin, turn over, or just start, etc.
RU saying you turn the key & nothing moves..? RU using multi-grade oil.? RU parked indoors or out in the cold.?
I thought all folks in cold country used elect. eng. blankets & elect. dip-stick heaters.
Take the bat. in one night...if it works in the morn. then a cold weather bat. may be in order.
All (bat.) cables & connections need to be clean.
BBroker72
Chattanooga, TN
Thank you for the Welcome!
The Bronco has been outside and I have never heard of anyone in the South using eng. blankets or dip-stick heaters. When I say the Bronco won't crank, I mean it won't turn over. All of the cables and connections are free of any corrosion and are tightly secured. I think I will take the battery inside tonight and see how that works. After all it is a Wal-Mart battery!
Cheers,
Broker
as the battery temperature declines, so does the minimum voltage. This is due to the effect of temperature on most chemical reactions. The battery reaction is slower as the electrolyte becomes cooler..." read more & see
TEMPERATURE-BATTY VOLATAGE CHART @ http://www.bbbind.com/BatteryLoadTest.pdf
and Walmart has some pretty good rated batteries for a price much lower than the same batty slapped w/a different label at parts stores.
Review, Walmart Everstart Maxx 65N; 850 CCA, 1000 CA (manufactured by Johnson Controls) Source: by miesk5 at Ford Bronco Zone Forums
I purchased this battery un NOV 07 at WAL MART
(battery is not listed in their web site)
It is mfg. by Johnson Controls & produces this EXACT SAME battery (CCA, etc.) for many auto makers and retailers under different product names such as:
Motorcraft Silver BXT-65-850; ~$100.00 to $120.00 Plus $104.95 + tax, etc. at your local friendly Ford dealer
Sears Die Hard Gold 33065 $105. +
Auto Zone (Duralast Gold)
Eveready
Everstart
Interstate Mega-Tron Plus $104.95 + tax, etc.
Toyota (TrueStart)
Mitsubishi (Diamond Car Care)
Mazda
Advance Auto (Autocraft Titanium)
Costco (Kirkland Signature)
Pep Boys (ProStart & Energizer)
btw, Johnson also mfg. Optima brand
WAL MART - excellent price $61.00 w/ 7% sales tax and free installation. The warranty is 3yr free and 108 month pro-rata
CCA: 875 amps @ 0 degree F/ CA = 1090 amps @ 32� F; Reserve capacity: 165 mins
compare CCA etc to Optima YellowTop
CCA = 500 amps @ 0 degree F/ CA = 625 amps at 32� F; Reserve capacity: 70 minutes
If you still have a prob, take it for a free load test at parts store
GL!
BBroker72
Chattanooga, TN
Hey GL,
Thank you for the information! I will take it for a load test and see what the outcome is. You're right, the great thing about the Wal-Mart Battery is the 3-year warranty, which I might be taking them up on.
Thank you again,
BBroker72
"......colder than say mid to high 20's."
"I have never heard of anyone in the South using eng. blankets or dip-stick heaters"
20's...???
Sounds like some-o-that good ole "global warming" made it down there to me... :D /emoticons/[email protected] 2x" width="20" height="20" />
Scodge
Buy an optima red top and a gear reduction starter. They have great gear reduction starters here: http://rjminjectiontech.com/collections/starters
If you don't find your rig listed, call them during the day and they can recommend the right one for your set up. I had starting problems with mine '67, but it was the starter/battery combo. Now it sounds lie a ferrari when I go to start it!
79' Buckin Bronco
