ttcole1254
- Joined
- Dec 27, 2013
- Messages
- 16
- Reaction score
- 0
This Bronco is about to hit the hay. I've replaced the alternator, starter, negative battery cable that was corroded, ignition switch, starter solenoid, and cleaned all the ground connections to the frame. But for some reason, after starting the truck once, running it for a bit, then shutting it back down, it refuses to start. It cranks, but extremely slowly.
The battery measures 12.9 volts with everything off, but 11.7 volts with the key in "On" which primes the fuel injectors and turns on the dash. Upon attempting to start, the battery drops to as low as 7 volts, and when I give up, the battery recovers to 11.3. Letting it sit for a few minutes brings it back to the 12.9.
If I throw a battery charger on it for an hour, it'll start like brand new. Battery measures 14 volts with the alternator running. We have tried a new battery as well, and the same thing happens.
If you guys know of anything it could be, I'm completely stumped. At this point I don't know what else there is.
Thanks!
Thanks!
