In Over My Head NEED HELP FROM THE 5.8L efi PROS
Fx4x4
I searched this Site but nothing really fit my situation.
I am using My 95 bronco with the 5.8 automatic that has a manual 4x4 . I have removed the entire body of the truck. I am using the chassis and putting a classic car body on the frame. Originally I wanted to re use the entire electrical system with the computer and the EFI. however it is really tight in the engine bay.
1. is it possible to eliminate all the emissions and vacuum stuff and keep the EFI... if so what is the best way to do so..
2. Can I just put a MSD ignition ,distributor, intake and carb, and a fuel pressure regulator ...and loose the computer, ERG and smog stuff..What else is there and what other issues will i run into that I have not thought about .
3. What that about the trans since it is automatic and has a 4x4 with the dog leg is there any reason the computer talks to the tranny... or can I just unplug the harnesses
Elmo
Forsyth Georgia
You can get rid of the emmission items with no problem. the vac items some you have to keep some you dont.
yes you can run a MSD and carb. you will have to add a stand alone controler for the trans.
F
Fx4x4
thanks for the insite... which trans controller do you guys like
F
Fx4x4
thanks for the link....i have a the e4od automatic trans ....Is there a specific trans controller any one can reccomend
