Im back, its been way too long
JLasvegas
I purchased another Bronco after all these years. I sold my 85 Bronco a few years ago and went thru a ton of different toys and always wanted to get back into another Bronco. Well I found a super clean 89 XLT Bronco and I will be back on this forum daily, as you all helped me so much in the past with my old Bronco.
Here is my new toy
Welcome to the 1989 club! What size are your wheels?
JLasvegas
JLasvegas
15" wheels with 32" BFGs
thanks guys, Its good to see so many guys and gals are still on here and active. not usually the case on alot of these forums.
JLasvegas
JLasvegas
First thing im working on is, the steering wheel is slightly wobbly probably due to the previous owner pulling himself into the cab, seems like a common problem. Im pretty positive its the upper bearing in the column and was gonna order one, but remember that in my 85 it was a PITA and I ended up replacing the entire column. Does anyone else suffer with a slightly loose wheel? Mine isnt bad at all but im very picky and want everything tight as it was when it rolled off the assembly line
yo J,
I have squeally upper Bearing in my 96, but no loose str wheel.
Ask local yard if they know of any column rebuilders in your area or can get one in VG condition for around $100.00 with $ back no Qs asked
http://www.mypartshop.com/
Select All Parts
year, etc, then FORD TRUCK
or
http://www.copartfinder.com
Has Vehicle Pics!
http://www.picknpull.com
Carson City
Sparks
http://www.car-parts.com/
Also for obsolete parts;
Our Sponsor here has been adding some to inventory; Jeff's Bronco Graveyard
and: by Ford pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
If I remember right, there is a bolt or two in there that tend to loosen up. Pull the wheel and check the mounting bolts for the tilt mechanism.
JLasvegas
JLasvegas
gentlemen, thank you for the info and links , I pulled the wheel and tightened everything I could, I also installed a Grant GT wheel and tightened that SOB so tight that the wheel would not turn haha, so I had to back it off alittle but just about all of the play is out of the column, still a very little bit but not anything to make me really wanna go crazy with it. I found a column used for $99 at a local wrecking yard but who knows if the bearings are any better in that, seems like a common problem
A tilt steering wheel does have a small amount of slop, you need it to take the pressure off the tilt gears when you want to change the angle of tilt.
JLasvegas
JLasvegas
I changed my wheels yesterday, went with some 15x10 steel wheels and couldnt be happier
Oldhenry1
