I'm a new 1993 Bronco owner and new here.
GrandpaKenof15
North Carolina
Hi all, I'm new to this site and just acquired a 1993 Bronco EB edition.
 I will be picking you guys brains as this project progresses as I come into the issues
that I know I am finding. Like getting rid of the old air pump system and so on. This ain't my first rodeo and I am
tech savy so any help I get and any I can help with I look forward to it. Will post pic later.
Ken
Welcome to the Zone >:D< <'> !  Post some pictures when you get a chance.  Also, please add the trucks vitals to your signature, it may help get better responses to questions.
GrandpaKenof15
GrandpaKenof15
North Carolina
Well I managed to get a couple of pictures uploaded. More will follow. Just gave it tires yesterday, now it's snowing so i'll work on it later. Got all fluids to change, gotta get rid of that crappy smog stuff, then new ignition and fuel injectors ( which I will rebuild myself) and then exhaust. It has been sitting since May and I just got it. Found out the rear axles slide in and out about 1/4 in or so. That about where I gotta get to before I can use it. It does run good, so I can't complain there. But I will greatly accept any and all help I can get and any ideas to consider would be fine too.
Ken
yo Ken,
WELCOME!
FYI,
96 Bronco-F-Series Workshop Manual (PARTIAL)
Same as most earlier years especially 92-96, excepts for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Axle Shaft End Play
Axle shaft end play is allowable up to 0.762mm (0.030 inch), but can be as low as 0.127mm (0.005 inch). It is controlled by the u-washer (4N237) that holds the axle shaft (4234) in the pocket of the differential side gear (4236). To reduce clearance, replace differential side gears, Traction-Lok® clutch plates if equipped, differential side gear ****** washers (4228) or axle shafts as required.
http://www.diesel-dave.com/vehic/manual/stj/stj52g17.htm
Section 05-02G: Axle, Integral Carrier, 8.8-Inch Ring Gear
REMOVAL AND INSTALLATION
Axle Shaft
http://www.diesel-dave.com/vehic/manual/stj/stj52g06.htm\\
GrandpaKenof15
GrandpaKenof15
North Carolina
Mostly the injectors that ford and Chrysler use. they are pretty simple. Just take them out and get the kits for them. I get mine off ebay.
GrandpaKenof15
GrandpaKenof15
North Carolina
To give you and idea, the injectors in a jeep 4.0l are the same type in a ford ranger 3.0l. But I went a step futher. I went to junk yard and found a 92 Lincoln with a 4.9l and pulled the injectors and carried them home. cleaned them up and ran the numbers to see what size they were. The ones in my b3000 were 13lb and the Lincoln's were 18.5lb. so I ordered the kit from ebay, about $20 or less for all 8. Then pulled the filter basket out of the tops and got a small paint can and filled it with berryman's b12 card cleaner and let them soak. made a power switch with a one way toggle and a injector connector so I could power the injector after soaking to blow out the trash. both directions. a rubber tipped air nozzle works best for this. then replace the new filter basket and O-rings and install. My mazda 3.0l is ported and polished, 18.5lb injectors, iridium plugs, crane fireball 6 ignition box. Now it has some of the most unbelievable bottom-end torque. It with redline in first gear with 16in tires and never pop the clutch. this from a rolling start, letting off the gas a then stomping it. cool huh
GrandpaKenof15
GrandpaKenof15
North Carolina
Thanks Ron,
I haven't gotten into the bronco yet. How do I determine what differential I have. I plan to go a little more extreme with the bronco. I guess summit racing is going to love me before the year is over. LOL.
Rons beast
Hey Gramps,
There should be a metal tag on the pumpkin cover. It has the code for the gears inside.  I don't have the decode but post them here and for sure Al, Bully or Seabronc will.
The possibility exists that the PO changed the gears. The old school way of determining ratio is the following:
This is easier with a buddy, but can be done alone with some ingenuity.
 1- safely jack up the rear
 2-mark a line on the drive shaft for reference. and one on the wheel that can turn free.
 3-hold one wheel from turning.
 4-with trans in neutral, turn the wheel and count the revolutions of the driveshaft. That's your gear ratio.
Good Luck
GrandpaKenof15
GrandpaKenof15
North Carolina
Weather is bitter cold tonite. Thanks for the reading info, I will be going thru the truck soon. The next project on the list is the start flushing of all fluids. Will be carrying this thread to a new discussion in info section. There I am going to list each step and what I find. Ought to be fun. I will try to add pictures.
Oldhenry1
