Thanks, that's the one I was giving. I've found this O'reillys by me to be notorious for giving out the wrong parts.more;From Advance Auto Parts;
Results for 1983 Ford Bronco :5.0L 302CI V8 Carb VIN: F
ACDelco Ignition Module/Control Unit
Part No. F1910 $91.99
Blue Grommet; Except California Emissions
BWD Ignition Module/Control Unit
Part No. CBE7Z $23.49
OE Style; Canada, Fed.
Part No. CBE11P
OE Style; Calif.
etc
How would I tell if its arcing and what do you mean by the cylinder?Could be a # of thangs; arcing; cap is loose (check spring clamps), rotor needs replacementAre sure it's not lifter noise at the cylinder next to the distributor?
All the wires are on tight.If the coil to distributor wire isn't in all the way it will give a loud snapping noise as the spark jumps the gap that it creates.
