wilsbronco
- Joined
- Oct 3, 2007
- Messages
- 25
- Reaction score
- 0
I am hoping someone can help me out. My bronco had some wiring issues ... windshield leaked, po had higher rated fuses than should have been in the panel, smoke, melted insulation, etc. I have rewired the affected circuits, which were primarily various lights, and got the windshield sealed. Now after working for a few days, it won't start. It's getting gas, starter turns strong, good battery, but no spark at the coil. I went through the tests in haynes and tested various things from the evt manual. Here's where things stand.
It's an 81, but has had the engine replaced with a fuel injected model, guessing 86 era based on what parts I find as matches when replacing. First, I accidentally broke the metal plug off the coil so replaced it even though the tests showed it was okay. I started with a spark tester and got nothing at the plugs, so I attached it to coil and no spark there either. The lightbulb test at the coil shows voltage, but no pulsing. So I moved up to the ignition control module (distributor mounted). According to Haynes, on pin 2 I should get somewhere near 12v when the key is in the "run" position. I get nothing. Now the wire goes to this rubber blob that has 1 green wire coming from the inside (ignition switch?) that gets split inside the rubber blob with a green wire going to the (-) of the ignition coil and the 2 pin of the control module connection. At the coil, I get the 12v, but not at pin 2. What is this rubber thing?? Is there a diode hiding in there or is it simply a splitter that's malfunctioning?
A brief history that may be applicable: ignition switch didn't talk to the fuel pump when I bought the bronco. Pump is now wired to a separate switch. With all my wiring issues, I have a feeling that the ignition switch isn't talking to the ignition control module and that's causing my problems (NOT a bad module). Before I cut the rubber blob out of the circuit, I wanted to make sure of what was going on. I'd live with wiring to another switch if that'd fix it.
Thanks
Thanks
