hydroboost brakes
scoutndmaggies76
central florida
wanting to add hydroboost to the brake system and im seeing lots of ways to do it. any help from those of you that have done this mod would be greatly appreciated. I already have PS with the canned ham pump with extra return so that wont be a problem. been looking for the hydro itself and found that late model f250 run this system. what would the difference be in the hydro from this and a hydro from an old bronco, astro van, mercury station wagon etc? thanks
bigbluebronc
ca
I would for go the hydro brakes unless your going with larger then 35 in tires, which in my opinion is as large as you should go without enlarging the wheelbase. I like three too one ratio 33 inch tires times three equals 99 inch wheelbase just a little too big for the bronco but works..A good power brake set up with disk front and drum rear shoud work great. Dont forget the proper proportioning valve. Turn the disks and drums add new pads and calipers and wheel cylinders and it should stop quite well.
BBB
S_bolt19
Colorado
First, sorry for my late response, I'm not much on here anymore, but I am gonna respectfully disagree with BBB, hydroboost isn't an overkill with any size tire by any means, it just gives an easier pedal when you go with disc brakes in front or on all 4 corners. The HB system is also more forgiving than the vacuum systems because once the engine dies, so does the vacuum system. Hydroboost allows you between 3 & 5 pumps of the brake pedal before it loses its power. Then it is the same as having manual brakes, just like the vacuum is. The main reason for adding hydro is because of the pressure needed with discs. The calipers are a lot harder to actuate than a wheel cylinder is and therefore having a hydraulic assist helps that much more. I've used or driven EBs with manual, vacuum & hydro systems in all three setups (drum/drum, disc/drum, disc, disc) and in my opinion, the hydro/disc/disc setup is the absolute best system there is. It is more responsive, has better stopping ability than any other combination. If you already have at least disc brakes up front, then I wouldn't hesitate at all in swapping to the HB system. If you still have drums all the way around, then I would caution against it because the pressure that an HB system creates, it can blow wheel cylinders out on a regular basis. At the very least, you should have a disc/drum setup before going to HB. Just my opinion, but the steps to get the HB system installed are pretty easy & any of the HB units out there will work. The most common one available and used is the Astrovan conversion. It's what I did and took me roughly 5-6 hours from start to finish. That time frame is with having all my supplies there of course. But do a search on it, I did a write up a few years ago on the install & it is pretty easy.
