hurst Floor shifter conversion
Jayson5150
Buckeye, AZ
I just installed my Floor shifter conversion and noticed that the 1/rev shift rod drags against the T-case shift rod....should I bend the 1/R rod or flip the rod from the T-case over? anyone else had this problem?
STLKIKN
Calgary Alberta
Jayson, did you receive two sets of rods with your shifter??
There are different rods for the t-shift and the j-shift t cases...
J
Jayson5150
Buckeye, AZ
I did receive both sets of rods and check p/n's for correct year....instructions did say some bending may be required....I just think that if I leave it alone it may cause damage down the road from the friction
