For a 92, correct?
If so;
Replacement, Front Wheel & Auto Hub Swap in a 90; and, Wheel Bearing Locknut Torque Settings for 80-96 MANUAL HUBS, NOT Factory Auto Hubs; Ford Pickups and Bronco; "...Using a lockout spanner (ford # T59T-1197-B or equivalent ) and a torque wrench, tighten the inner bearing adjusting nut to 50 foot pounds while rotating the wheel back and forth and seating the bearing. Back off the adjusting nut approximately 45 degrees. Assemble the lock washer by turning the inner lockout to align the pin with the nearest hole in the lock washer. To lock it, install the outer lock nut and tighten it to 150 foot pounds. Grab the top of the tire with one hand and the bottom of the tire with the other. Move the tire in and out on the spindle. End play should be less than .006 – inch.).." Thanks to Chris!!!!
Source: by 90Beater (Topher, Chris) at
http://bronco.tophersworld.com/writeup_hubs.htm
compare with;
Replacement, Front Wheel Video in a 94 Part 1; MIESK5 Note, Suggest Right Clicking this Hot Link & Open in New Window
Source: by pfun41 at youtube.com
http://www.youtube.com/user/pfun41#p/search/44/SYkmL0wR2lg
Part 2; MIESK5 Note, Suggest Right Clicking this Hot Link & Open in New Window
http://www.youtube.com/user/pfun41#p/search/45/eNbDwF08X6k
Replacement, in a 91
Source: by DcSkater602 (Steve) at
http://www.supermotors.net/registry/9901/30187
Parts Break-Out Diagrams w/ Auto & Manual Locking Hubs & BoM; 6 MB PDF see page 121
Source: by dana @
http://www2.dana.com/pdf/X510-9.pdf
Wheel Bearing Locknut Torque Settings for 80-96 MANUAL HUBS, NOT Factory Auto Hubs; Ford Pickups and Bronco; "...Using a lockout spanner (Ford # T59T-1197-B or equivalent) and a torque wrench, tighten the inner bearing adjusting nut to 50 foot pounds while rotating the wheel back and forth and seating the bearing. Back off the adjusting nut approximately 45 degrees. Assemble the lock washer by turning the inner lockout to align the pin with the nearest hole in the lock washer. To lock it, install the outer lock nut and tighten it to 150 foot pounds. Grab the top of the tire with one hand and the bottom of the tire with the other. Move the tire in and out on the spindle. End play should be less than .006 – inch.).." Thanks to Chris!
Source: by miesk5 at Ford Bronco Zone Forums
Spindle Differences '80-96
In addition to the ~'92 loss of a spindle stud (leaving 5) and the addition of 2 notches in the spindle ****** (Bronco only) for the 4WABS sensor used on '93-96 Broncos only, the spindle was also redesigned in ~'95 to match the revised 2-piece inner wheel seal. F150 spindle flanges were never notched or drilled for the 4WABS sensor, but are otherwise identical to the corresponding Bronco's.
I suspect the slot was lengthened around '86 for the self-locking spindle nut, but I haven't confirmed that.
'87-early '88 spindles for manual (top-hat ******-style) hub locks are significantly shorter overall, take a 1-piece hub/rotor, and have 6 stud holes.
by Steve @
http://www.supermotors.net/registry/media/728442
