how to get 22 more hp...is this for real???, I found this thing on Eba
jaminjimlp
Griffin, Ga.
here's what the add says:
"The Progressive tuner simply wires into the factory socket already under the hood of your vehicle. Like the name suggests, you will instantly notice an improvement in response, acceleration, torque, and horsepower, or your money back. Don't be fooled into believing that expensive ECU units are the only way to safely and legally give your vehicle that extra kick!
THIS IS NOT A CHIP!!!
Once installed, locate an area near the drivers seat to adjust the tuner. When the tuners boost dial is low, you should see a gain of about 7-10HP and should get the same gas mileage as stock. When you turn the boost up, you should see a gain of about 15-22 hp. At full boost gas mileage will decrease about 2mpg but what will you care when your getting all the extra power!!!
This is better than nitrous without The Nitrous effects on the motor.
The Progressive Tuner simply wires into the factory harness of the IAT sensor. The module will work with the sensor to provide a new signal to your vehicles computer, or ECU. The ECU then adjusts your air/fuel and timing advance curves to new performance settings. Our progressive tuner eliminates costly parts and installation of ECU components (many ECU mods require you to solder and modify the main board), and still safely and legally provides the same end results. There is no risk of damage to the engine or electrical system since the modified sensor signal will always remain within the manufacturer
Good ratings and lots of sales don't equate to actual HP gain :-& #036; Get one and do some sort of controlled testing and let us know how well it works.
BIGWILL-5811
HAVENOT, NC
All those comp. chips do is let your motor "breath" and "push" more exhaust by trickin into thinking its runnin harder then it is. your more likly to see 5-10 hp gain. if you want 22 hp get an exhaust, intake and throtle spacer, you'll get better milage with them also.
digs
