Orangecrush
- Joined
- Apr 11, 2005
- Messages
- 98
- Reaction score
- 0
Okay, my truck runs GREAT when warm. However, it doesn't want to start. I mean it's really an art to get this thing running. My first suspicion is that the timing is off, most likely too ********?
First, here are the symptoms: cranks and cranks with hardly a sputter when cold. If you pump the peddel, eventually you'll get it to catch just for a second. Once it does start to catch, you have to continue to crank it (great for the starter /emoticons/[email protected] 2x" width="20" height="20" /> ) and pump the throttle. Once it gets to the point where it MAY run on it's own you have to continue pumping the throttle. The weird thing is that the engine "bounces" at this piont. It is sort of like it's running and then not then running then not, almost like the key is being turned off and on and off and on....... This goes on for maybe 5-7 seconds. Then, it roars like normal. I'm thinking this could be the timing not being advanced due to low ported vacuum but then bouncing back to advance and so on and so on. It also like to backfire when trying to start (fuel not burt).
Now, assuming this may be a problem with the initial timing, I want to be able to adjust.
I know how to rotate the distributor clockwise to advance and counterclock to ******. The problem is that the vacuum mechanism is as far as it can go and is hitting the water inlet neck. I understand that there is a way (if it turns out that retarding the timing makes it worse) to advance the spark more by moving the distributor to another tooth on the cam.
Can someone walk me through, step by step, how to accomplish this??
