I wouldn't get up there and walk around but I'm sure it can support a tire and rack. A little reinforcing, like plated inside will help. The top is a double walled fiber glass structure. Wear a dust mask while drilling it since you will have fiberglass dust flying around. If mounting directly to the top, I would fabricate the feet with a square plate about 4" x 4" and have the same size plate inside to bolt to in the four corners of each plate.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Yeah I have definatley stood, sat and slept on the top of my bronco, standing sure put alot of pressure on one spot that cause the top to flex a bit but they are very strong, I was about 200lbs at the time.
Also I took my bronco into an underground parking garage and hit a few pipes. the pipes compressed the suspension, dinted my metal roof, and ripped off the cb antenna. bu the fiberglass top only scratched the paint off of it. that was the force of the entire suspension system pushing back on it. I never went in there again. and my cherry bomb set off some car alarms, its was funny later.
stock broncos will fit no problem for those who got worried, mine is lifted about 3 inches on the front and 4 on the back and had 33's at the time.
