wolf83
i think i found a donor vehicle, but since i have never done this before, i am not sure what to look for in a good donor. i would like to upgrade to v8, but i also need some body panels, glass, etc...
here is the question...
will it save me money in the long run if the donor has the powerplant i want but bad body? or should i pick a donor with a good body and bad powerplant?
whatever part is bad, i would have to buy it by itself.
bottom line is this: is body work cheaper to do in the long run, or is "guts" work cheaper?
i own an 83 bronco 6cyl and i found an 86 f150 2wd 351cid for a possible donor (for its powerplant)
thanks
thanks
