Horn Doesnt work
xplosiveg06
does anyone have a list of things for me to check what the problem is ?
so far i just checked the fuse and it looks good.
I could be any number of things. With a METER, check for 12V at the horn when the horn button/bar is pushed. If you have 12V, try running a ground wire to the horn from the battery, (clean up a spot on the mount to touch it to). If that works take the horn off and clean up the ground connection. If no 12V and you have cruise control, you have a horn relay. Also if you have cruise control, the horn relay is grounded through a brush in the steering column, if that one is bad, your cruise control should also be failing.
Not sure that I can really help you troubleshoot it, I've had the problem a few times and I don't ***** around with it, I've taken 2 routes in the past (variations on a theme) first you can just by-pass the whole thing & just run a couple new wires to the existing horn switch in the wheel or just run new wires to a new mushroom switch somewhere convenient. Might not be your style but I've also just run new wiring to a second boneyard headlight dimmer which really worked for me since I REALLY enjoyed just jamming my foot down when I wanted to use the horn on some pinhead in front of me. Your mileage may very
Elmomo
