rockstar1489
- Joined
- Mar 7, 2007
- Messages
- 14
- Reaction score
- 0
I have a 94 XLT bronco. My horn and cruise control stopped working..also my airbag light is on so im guessing that it isn't working either... i need help >-
i had the recall done but i think it is the clockspring..that was my first guess... would i be able to use a clockspring from a later year bronco like an 89? and how much does a clockspring go for?yo!
Cruise (Speed) Control DEACTIVATION SWITCH Recall for 94-02 F-150, 97-02 Expedition, 98-02 Lincoln Navigators & 94-96 Bronco NHTSA CAMPAIGN ID Number : 05V017000 Recall Date : JAN 27, 2005 (search for 05V017000 in "Safety Recalls) Source: by National Highway Traffic Safety Administration nhtsa.dot.gov
also,
If a fault code is flashing on the airbag restraint system light and/or if there is an inoperative horn, they are often related to an inoperative speed control system caused by a faulty clockspring.
http://www.asashop.org/autoinc/nov2002/techtips.htm
/emoticons/[email protected] 2x" width="20" height="20" /> kool thanks man hmm.. how much do you think labor would cost to have it installed...i have an airbag..yo!Here are some clock spring replacement write-ups:
http://www.broncolinks.com/admin/admineditlink.php?index=775
ok, found this for your 94; doubt that the parts are same; ask Frod Dealer parts manager; or if I can, will ck Motor Craft Catalog later and let you know; no go; call dealer
http://www.shop.com/op/~Dorman_Clock_Sprin...s-prod-26354701
Dorman Clock Spring 1994 Ford Bronco F Series PUs
Item DOR-525-200
Was $123.74
Now $82.49
You Save $41.25
very careful with this sys. it can hurt you!
and the puller is about $18.00
plus Torx bit will prob be needed
yw/emoticons/[email protected] 2x" width="20" height="20" /> kool thanks man hmm.. how much do you think labor would cost to have it installed...i have an airbag..
