Highlighted posts from Tuesday, Jan. 04, 2022
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
December 31, 2021 * 9 posts * 398 views
Melmac39 said: My Bronco is stock (79 Custom) but one thing the previous owner did was remove the cat converter and then installed dual exhaust to come out just behind the doors. I hate the setup. ... Read more >>
December 30, 2021 * 15 posts * 493 views
Js32274 said: Hey guys. I have wanted a Bronco since I was 16. 25 years later I got one! This is a 1979 Bronco, great interior. I will be working on body and a new paint job this year. I do ... Read more >>
January 02, 2022 * 5 posts * 127 views
ablediver said: I'm having a problem with acceleration in my 90' Bronco FS XLT with a 5.0. The vehicle has been stored periods up to 4-5 months (absent due to work) at a time. The tank has been ... Read more >>
January 01, 2022 * 5 posts * 370 views
Daves1971 said: Hi all. My 1971 with theDana 20 will not go into 4wd high. All the rest works fine. The rail on drivers side does not appear to slide fore and aft like the passenger side rail. ... Read more >>
December 29, 2021 * 3 posts * 298 views
Broncosandpartsgarage said: Ford Bronco Tailgate Repair & ASSEMBLY: Part 3 of 3 [link] Read more >>
January 03, 2022 * 1 post * 63 views
Js32274 said: Hey guys. First question. My '79 I just bought has very low lights on the dash board when I drive at night. It is hard to see the gauges. Do I replace the bulbs? Do I have to take ... Read more >>
January 03, 2022 * 1 post * 10 views
Emelio said: I'm looking for a 17-1/2" in diameter air cleaner cover for my 1986 Bronco XLT... Read more >>
January 03, 2022 * 23 posts * 1,179 views
miesk5 said: Yo T, ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center: US: ... Read more >>
January 03, 2022 * 9 posts * 597 views
chrlsful said: they had nuttin on site, thnx 4 referral anyway. ("...get an O'reilly EEC..." re-flashed, "...made to order...") Read more >>
January 03, 2022 * 4 posts * 361 views
EJ in GA said: Found the problem. Loose wire on the solenoid. Got lucky this time. Something simple. Just took time chasing wires. Read more >>
Continue reading...
Similar threads
T
Replies
Views
1K
T
T
Replies
Views
878
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
Eldorondo
