HIGH PRESSURE FUEL LINE FOR 1989 BRONCO 351 W.
pewter47
NEED HELP FINDING A HIGH PRESSURE FUEL LINE FOR A 1989 BRONCO WITH A 351 WINDSOR. FORD QUIT MAKING THEM, AND I HAVE SOME KIND OF ANIMAL THAT HAS BIT THROUGH 3 OF THEM I HAVE FOUND.
I have a set that I will be taking off my Bronc. Not too sure how easy they would be to ship though. where are you located?
captsb890
Arizona
Plant City, Fl. 33565 just out side of Tampa
Do you have a full size 89 bronco-? there is a hard nylon gas line from the back of the rail pump about 3 feet long heading back to the tank pump---you have that line? Has quick disconnect fittings on it-- Thanks Sam
johnnyreb
West Virginia
solve the animal problem first--then get a new hose.
Kingdalt777
