Help with 94 Bronco
tjsgmith
I have 2 questions to send out :p /emoticons/[email protected] 2x" width="20" height="20" />
1. I took the top off my 94 bronco and lost the screws to put it back on. Anyone know where/what kind to get?
2. The brake/hazard lights went out. I changed the fuse but that didn't work. Any suggestions for a novice, broke, fix it yourselfer?
muddog
Indianapolis, IN
on my 93 i had to cut all the bolts off cause they were seized. i drilled all the holes all the way through then ran a metal strip under the railing and used hardened steel nuts and bolts. actually easier that those stupid torx strews.
bigtrux
Murrieta,CA
1st issue lost bolts a good local hardware store not lowes but like a mom and pop store like true value stores usually have a good assortment so you can find replacement bolts or both bolts and the anchor nuts that hold it in place.
2nd issue brake lights/ hazard i would check the light switch mine had a wire coming lose arcing out or the fuses. good luck.....
19Bronco93
Camden, DE
1st issue... get something different than the torx bolts. i am sure you know what a pain they are by taking them off. its probably better to lose them
2nd issue... check to see if you have current flowing to the wires. if not, follow the wires. sounds like i wire got snipped or snagged somewheres
walnuts75
Ohio
Try either a hardware store or Autozone. I've lost several of those clips and bolts myself. Autozone has both the right sized torx bolts and clips. But like 19bronco93 said, you should find something other than torx.
Virgil3rd
