6.2 Can I get a soft top for my Bronco?Yes. Soft tops are available in 3 different styles. First is a jeep-type soft top with a frame that has the same interior volume as the hard top. Second is a tonneau cover that runs along the steel/fiberglass boundary. Kinda makes the truck look like a very short bed pickup with a "racerback" type fairing. The third that I'm aware of is a two part tonneau cover that consists of a bulkhead piece and a tonneau piece. The bulkhead closes off the back of the cab and extends from the roof line to the floor, leaving the Bronco like an open bed pickup. The second piece covers the bed, similar to the one-piece tonneau cover.
Style number one is made by Kayline. Number two is made by Skyler. Number three is made by (or for) K Bar S.
6.3 How come there isn't a soft top available for 92+ Broncos?
In 1992 Ford added a high mount third brake light to the fiberglass top. They also added shoulder belts for the back seat passengers. The shoulder belt mounting points are attached to the fiberglass top. Because of these new safety features, top manufacturers will not recomended that the top on 92-96 Broncos be removed. The soft tops for earlier models WILL FIT 92 and newer Broncos, but the third brake light will be removed with the hard top, and back seat passengers will be without seatbelts.
Because the hardtop on '92 and newer Broncos contains safety items (brake light, seatbelt mounts), soft top manufacturers and Off-Road.Com do not advocate removing it.
