Help needed with timing
91 Bogger
Waterford, MI.
Hey every body. Need a little help if anyone can. trying to figure out rough timing setting for a 302 bored .030 over with 10.0:1 compression. Any help would be great.
50joe
Trenton NJ
I'm no engine builder, but I'm guessing your going to have to play around with it to find the sweet spot. I remember when I changed the cam in my mustang the best spot was 14 degrees BTDC. Might wanna start with the factory 10 and play with it from there.
Bronc76
If you have the info that came with cam, the setting is on there.
yo!
GL with it!
I agree w/ the guys on this and some info by a good pal. Sixlitre Tune-Up Info "...Yes, stock timing is 10 degrees, I find optimum timing to be almost exactly 13.5 but you can play around until you notice ping and then back off 2 degrees if you want to, and/or tune by vacuum if you care to. Cheapest Autolites money can buy, nuthin' platinum, nuthin' fancy, just set out to .055 gap..."
Distributor, Vacuum, Tuning Tips - mostly for vacuum advance distributors; "...If your vacuum canister isn't adjustable, get one aftermarket, your mileage jump will pay for it. Better have good plug wires and gap plugs to Ford or MSD specs..."
Source: by Sixlitre (Malcolm H, Eddie Bauer) at http://www.superford.org/registry/vehicles/detail.php?id=4970&s=17585#content
Bronc094
