Help needed in removing body mounts from frame
chesbronco
I just removed the body of my 69' wagon's body from the frame yesterday. There were 8 body bolts. Underneath were thick rubber grommets that lookeed as if they are pressed into the frame. There are also top and bottom washers that appear to be threaded. Is there a special tool to remove these from the frame? Need to get them out before sandblasting.
walkercreekbronco
I used a sawzall. It's quick, but not pleasant due to all the vibration sent back to your arms (enough to make your skin itch).
frdbronco73
Chicago, IL
I used a combination of a big hammer a chisel and a little help from a torch(recommend doing it outside my mistake).
4linkbronc
The torch!! Easiest way Tried screwdriver, chisil, hammer, everything. Shoulda used a torch the first time.
79' Buckin Bronco
