Heater core tubes
project71
Should the two tubes on the heater core that extend thru the fire wall come straight thru the fire wall or be at an angle? Mine is at an angle. I had removed it during a frame off I am doing and also replaced the firewall insulation behind it. Everything looks tight, but the angle they are at doesn't leave much tube to clamp on the hoses. Help!
project71
project71
I should add that I did not disassemble the heater itself, just removed it and reinstalled it. I guess I didn't notice how it was prior to removal.
project71
project71
Also should have noted it's a 71 Bronco with 302.
I am pretty sure they stick through the firewall, but not very much. Will try to find a picture.
I cannot find any decent pictures of how far they stick through the firewall but it is just enough to get a hose clamp on.
Hope that helps.
Staff online
Root710
