So in the process of cleaning out all the leaves and what not from my hvac system i pulled the heater core out and when i went to dump what was in it all the fluid came out only one side and what little came out the other was full of rust flakes, would a clogged/restricted heater core cause overheating To some degree? I ask because i have a 3 row all aluminum radiator and 180 tstat, new water pump, all new lines, and 4 electric fans (1x16" 3x12") that kick on at 200 and off at 180 but still overheat climbing hills or pulling a small atv trailer, have a vdo temp gauge with the correct sensor. Its really intermittent, ive pulled several other vehicles with it no problem, but then out of the blue itll start overheating and once it starts to itll never come back down until i shut it down and wait for a few hours, any help on this would most definitely be appreciated
My 90 with a 302 overheated ONCE. I already had a new heater core, therm and housing, hoses etc... I flushed everything and upgraded to heavy duty water pump AND heavy duty fan clutch. No more over heating.
