Your best bet would be a auto parts recycler, but they may not be in too good of shape. An upholstery shop could probably make you one.just got a 1980 bronco and starting to work on it. but I can not fine a headliner for it can anyone help
yeap sound simple enough but only thing is who ever had before me took the whole thing out and I dont have the hard panel to put the padding on. but thanks for the helpI have a 1984 FSB, my headliner is on a panel you can drop once you remove the trim. Just get some thin padding from our local craft shop, cut to fit. Same with whatever you want the headliner to be made of and they also sell a spray adhesive you can buy to stick it all together.
Sounds simple enough huh....
Bufford
You will probably have to find one locally, those hard panels are made of pressed foam and don't handle well, especially in shipment without special packing and box. Because of it's size the cost of shipping would probably be pretty high in spite of the fact that they are light weight.yeap sound simple enough but only thing is who ever had before me took the whole thing out and I dont have the hard panel to put the padding on. but thanks for the help
bigjohn
