Headers
Bamafan
I am replacing the headers on my 74 Bronco. I currently have ****** headers I believe. I am trying to decide between Duffs ceramic coated and Ultra flows from Jeff's bronco graveyard. Any suggestions or recommendations?? I have a 302 with 351W heads, any problems with install of either? Thanks in advance.
P
Patrick
Guest
I have a 77 and installed Duff ceramic headers last year. installation was so easy i was able to do it by myself. I would strongly recommend a ceramic coating as they run cooler and look great!
Flash69
Va
I have the ultra flow from Jeffs.They are warrantied for life.They do discolor tho.If you want good looks then ceramic would be the way to go.
T
trips
Guest
Get your new headers from JetHot. They ceramic coat heads. Have them coat a set of Hedman headers,"Hedman uses a heavy ****** [that bolts to your cylinder head] it will not warp." Buy the headers from JetHot,"it will save you shipping." JetHot has the best coating.
G
Guest
Guest
classicbronco.com is having a mass buy right now on the Jet Hot long tube headmans....
okiebronco
I sure am glad I found this site! Thanks to the people who helped me order these headers. I saved almost $50.00 by going in on the mass buy! Thanks again!! Jeff ('71 Bronco Sport Rust Bucket )
harleyds
I put in the L & L Ultras from the bronco graveyard. They have a 1/2" ****** which means they will never warp. Flanges are usually a header weak spot
Harley
ser
:D /emoticons/[email protected] 2x" width="20" height="20" /> I just installed dynomax headers on my 67 and it was fairly easy also. Wow can you feel the difference in the seat monitor.
bigdave
Guest
I recently purchased Heddman Elite series headers from Summit which have a great warranty and are much cheaper than the headers available from the Bronco sites even though they are ceramic or something coated and have a 3/8 in. ******.
Check them out at summit.com
Bandit
BANDIT
Afton,Wyoming
:-B
5294[/snapback]
Ive been looking at the wild horses titaniam coated,have you seen em?
BroncoBernie
Greenbay wisconsin
:) I installed the Duffs ceramic headers I like them so far,Be very careful with the install they can scrach if you ruff them up. Here is a photo with the headers. :-"
:-B Ive been looking at the wild horses titaniam coated,have you seen em?
17349[/snapback]
BroncoBernie
Greenbay wisconsin
YES VERY NICE HEADERS. I think they are more expensive than Duffs. I went with duffs because they have the exhaust package . And I wanted to save with the labor and do it myself.
