Header Clearence
ROCHMPR
Hello out there! I got a question about clearance. I have a '72 and I'm putting full width axles, front and rear. The front axle is a reverse cut high pinion and the housing is hitting the header on the driver side. I don't know what kind of header it is, all I know is that it's in the way. A standard cut fits in fine, but it's still close. I would like to use the high angle, but I don't know what header I can use. Has anybody run into this problem? If so what can I use. :unsure:
tsebalj
