Having Problems With My Lights
Shadow_D
Schenectady, NY
It sounds like you have corrosion in your plugs.
Have you been blowing fuses? If so you have a short.
If not then you need to pull all the plugs off the lights and start cleaning everything with a wire brush (make sure the lights are OFF).
After cleaning I use petroleum jelly in the plugs to help keep the corrosion out.
walkdawg
Jacksonville North Carolina
I agree with shadow d. There is some corrosion causing some resistance. I would check all connections even the connection on the alt. and the battery.
