Hard Shifting Transmission
engage parking brake all da way; put it in low, rev the engine .. don't float da valves! ; and if da shifter slams all over da place, suspect the mounts. btw the shifter will move quite a bit even with good mounts, but a bad one will show up.... ... look under while someone does it and try not to get rolled over; I do same /motor mounts....
As Joe advised Check for Codes.... an iffy MLPS can do this too esp w/intermittent hard shifts.
Matt_V
Have Bronco....need money.
Oops I guess I should have read that better :blink:
It was a good suggestion for those of us with older transmissions though, I had that exact problem and found the vacuum hose disconnected from mine. Hooked it up and it shifts much better now. Of course, the fluid change helped too.
JohnK
