Gear Bound
Buschman
Ohio
Ok. I’ve been looking and maybe I missed the tread to answer my questions or maybe it just can’t be done or in my case there is a easier way. So I took a Bronco 2 body and put it on a 1982 full size Bronco that has a c-6 tranny. It will do 0 to 60 in about 60 seconds if you can get the tires to hook up😎 but, the small block 302 is at 3500 rpm at 55 mph. I have very cheap access to the AOD tranny. My c-6 has 1,2 and drive. My understanding is the AOD has 1,2,3 and drive. Is this a logical choice? What kind of headache will I have?
I think the AOD would be a great upgrade. I believe that you will need different length driveshafts, and to avoid any issues with the column shift I would consider a floorshifter.
Yo Buschman,
As Skitter advised.
C6 to AOD Swap by j. r. Nice is detailed and has many pictures.
Tips:
AOD Throttle Valve TV) Cable, (Linkage) Adjustment Info by Baumann @ https://www.becontrols.com/tvlinkage.shtml
➡️"NOTHING can ruin an AOD transmission as quickly as improper TV settings.⚠️ If you are unclear or uncomfortable with the procedure, do not attempt this adjustment yourself."
Quality Replacement Parts | Find Used Auto Parts | Online Locator
A yard that uses Hollander Interchange can search other yards and have it shipped including some Canadian yards.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @: Seller Directory | Used Auto Parts | Hollanderparts
Can select a certain part.
Search: 1989 >Ford > Bronco > Transmission > Transmission Transaxle > 02967A At, Aod Transmission
or
Can select certain parts
Has Vehicle Pics for some vehicles incl. interior/dash, back seat, front & rear and engine bay
Bronco Used Part Search @ Ford Bronco Parts | Used Auto Parts with source, cost, yard and phone #
Concord Spare Parts @ Spare parts for your cars, trucks and special vehicles
732-374-3872
[email protected]
Home | Pick-n-Pull
This is a Company name w/yard locations in various states
Can NOT Select certain parts
B&R Autowrecking, in CA, WA, NV, OR. "We have a fleet of over 60 trucks that deliver to business addresses all over Oregon and Washington. Outside of Oregon and Washington, we have daily shipping services. Contact Us for a quote."
"Will ship to their closest yard for $50 flat" by StemCellResearch", 2019
Row52
AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
For obsolete parts by Ford long version pn:
Welcome to the PartsVoice Parts Locator
Rear Counter Auto Parts Locator
http://www.greensalescompany.com
https://nospartsltd.com
And by a search function;
https://autopartsobsolete.com/truck-ford/
For new discounted Ford parts:
https://consumerlink.oeconnection.com/91554453363118850 (suggested by JScatt!)
EEC 3 aka EECIII Testing, vacuum & wiring diagrams, locations, etc in an 82 by Tommy @ Wayback Machine
"Woe was me, when I found out my 82 Ford Bronco was an EEC 3!
I had searched all over the engine compartment for the infamous "self test connector", only to find NONE.
Finally figuring it probably was a pre EEC 4 system, my disappointment turned to reality, when I discovered the printed EEC III label on the ECU."
1981 Bronco/F Series Electrical & Vacuum Troubleshooting Manual (EVTM), partial via Gary @ 1981 EVTM - Gary's Garagemahal (the Bullnose bible) many items are similar to your 82.
Bronco/F Series Specifications by Gary @ Axle Ratios - Gary's Garagemahal (the Bullnose bible)
See more info by Gary!
GL!
Buschman
Buschman
Ohio
Wow! I see the AOD May not be the best option. I may look into a add on external over drive for the c-6 that runs off a switch. I have a lot of looking to do. I do have a free AOD I don’t know if the tail spline is the same as my transfer case? Wow thanks guys🧐
Buschman
Buschman
Ohio
Ok, l noticed today that my c-6 when decelerating that between 35 - 30 it shifts down and shifts down rather hard. Is this a modulator or are my bands to tight? I guess I might have to check atf pressures again? It may not be broke in yet? Maybe I messed it up to ******* it? Wishing trannys were my strong suit🤪
Yo Buschman,
BINGO!
Pull the vacuum line off the modulator. If fluid flows out, the modulator's diaphram ruptured and modulator needs to be replaced. If no fluid in modulator, chock tires, parking brake on, pull hose and check vacuum at modulator. Should be around 17" and 21" HG; if not inspect vacuum hose back to intake manifold.Screenshot_20200225-083549.jpg
bigd1948
