gas gauge
bigblue35
My gas gauge is always messing up and off by alot, how could i upgrade my gas tank reader to no be a floater and work like a newer style vehicle. who all has done this?
BroncoJoe19
the problem may be the sender, the guage, the wiring, or a bad ground.
You might consider checking the above, just short of dropping the tank (following the info presented above) and just keep a gas log, until you need to drop the tank to make fuel pump repair.
Gas guage, oil pressure guage, fuel guage
http://broncozone.com/forums/index.php?s=&...ost&p=29198
Bronco fuel pump access panel
If you need to get to the pump, you can either drop the tank, or cut an access panel in the cargo area.
Sender Unit Access Panel - Ford Bronco Zone Forums
digs
