fuse
bigbronc2632
i need to know about a 89 bronco the ac fuse in it when i bout it is a 15 watt but the guy put wires around it to overide it and it heats up and could cause a fire but i need ac cus i live in florida what watt should i put in and would upping the watts do anything to damage the electrical system at all
For a quick reference, look on the inside of the fuse panel cover, or the black plastic lid over the fuse box. It should have a diagram of the fuse locations, what they are for, and the size they should be. You need to find out why the AC circuit keeps blowing fuses, though, if it was bypassed. A short in the wiring could possibly cause a fire, or at the very least burn up more wiring.
Fuse #6 for the AC clutch is a 15 amp unit.
29556[/snapback]
yep, could be that the A/C clutch coil is shorted; and as just advised, other wiring shorts.
firelt90bronco
Ask me about my job
northeast
Fuses are designed as a failsafe to electrical loads, uping the amps will not damage anything. Fuses should be atleast 3 times the wires amperage.
bigbronc2632
bigbronc2632
thanx yall i upped the fuse to a 25 watt for now because i just need something to keep it going but at least its not dangerous like a bypassed fuse i am planning on fixing it in the near future i just need my ac living in florida because even in the winter it still gets hot
29632[/snapback]
If you have a problem that is causing fuses to ***** upping the amperage may work in the short term. But just like house wiring, incrasing a fuse presents a potential fire hazard. If the short is a high resistance short, the result is excesive heat and FIRE.
A fuse should definately NOT be 3 times the rating of the wire. It should never exceed the safe rating of the wire so if the wire that it is connected to is rated at 15 amps, putting a 25 amp fuse in is asking for a fire. Find out what the problem is and fix it, but it is your truck :) /emoticons/smile@2x.png 2x" width="20" height="20" /> . They are there for two purposes; 1. to prevent a fire and 2. to protect the attached equipment.
bigbronc2632
bigbronc2632
i went online and found a wiring diagram and it said that the ac fuse that was blowin was supposed to be a 30 amp fuse so i changed it up and it works fine now doesnt heat up or anything
denny.dikes
