fule milage
YO WH,
Fuel Saving Tips
Reduce Cargo Weight
Under inflated tires Increase rolling resistance 1-2 mpg;
Dirty air filter Causes excessively rich fuel/air mixture 2.0 mpg;
Worn spark plugs Cause inefficient combustion, wasted fuel 2.0 mpg;
Worn O2 sensor Unable to detect and adjust air/fuel mixture 3 mpg;
Dirty or substandard engine oil Increases internal engine friction 0.4 mpg;
Loose gas cap Allows fuel to evaporate 2.0 mpg; P
Potential loss in fuel economy if all of the above were neglected 11.4 mpg
Fuel Economy Tech Tips TSB 99-26-09 for 90-96 Bronco, 90-97 F Series, Aerostar, F 350; 90-92 Ranger & Econoline; 91-2000 Explorer; 95-2000 Windstar; 97-2000 Expedition & Many Others
http://www.thedieselstop.com/faq/9497faq/tsb/tsb/files/992609.pdf
Too bad over inflated tires kills traction. I got +1mpg when I did that (accidentally) :-"
The big thing is to keep a smooth running engine. If it has to work to stay running that kills gas. I know I get 8-9mpg's and I have some stuff to take care of. Another gas killer is stomping on it off the line. Your 1986 302³in makes 250 ft/lb @ 2000 rpm. Make the torque work for ya w/out lugg'n the engine.
:) /emoticons/[email protected] 2x" width="20" height="20" />
All good suggestions, but just so you don't get your expectations up too high, Bronco's weren't designed with fuel economy in mind. The best I have ever heard of anyone getting is around 17 MPG and that is few and far between. Most Full Size Bronco's get 10 MPG or less around town and maybe 12 to 13 on long highway cruises.
Elmo
Forsyth Georgia
i get 10.5 mpg with a 351 running 355 gears and 35s. feel lucky that i get that. if a person wants high mpg a fullsize offroad capable 4x4 aint the right ride. i understand we all want to get the best that we can get, but we also have to keep in mind what foundation we are working with.
rubberdust
Henderson NV
Broncos are not an economy vehicle I get excited when I get anything over 9 MPG in my 92, but with 4.56 gears & all the stuff I haul. Even when I ghanged engines it didn't matter. My 95 which is pretty stock has maybe seen 12 MPG once.
nelbur
The secret to enjoying a Bronco is to NEVER calculate the gas mileage. It's about as aerodynamic as a brick.
Mgough
