fuel relay
jlb
Detroit Mich
I went to replace my fuel pump relay on my 90 bronco 351 and noticed I had a broken wire so I bought a new connector with harness so I could just splice it together but then i noticed There was 5 wires going into the relay from the old harness but there is only 4 on the new one so I guess what im asking could it be the wrong connector or could be a different design the connector its self is green or could it be possible its not even the fuel pump relay harness that needs replacing.
In your year, the FP relay is Green and EEC Power Relay is Brown
Look @ wire colors, assuming a po or shop didn't rig it up
here is a wiring diagram showing both Relays;
Wiring Diagram in a 90
Source: by Seattle FSB (SeattleFSB) at http://www.supermotors.net/registry/media/854315
other diagrams, such as by Chilton show 5 wires to the EEC Power Relay (two Yellow instead on one; could have been a Ford change using the relay instead of a splice for the yellow)
http://content.chiltonsonline.com/content/images/8828/images/88286w09.pdf
I'll try & find the othewr relays' diagrams; but info from other owners is sketchy due to rig jobs through the years; maybe someone else here can post the info up for you.
TSB 89-14-17 Trailer Wiring Colors
1990 BRONCO, F-150, F-250, F-350
Trailer tow wire harness color codes have been revised to be compatible with SAE color code standards. When hooking up a vehicle to a trailer that has been wired according to the SAE standard, the wire color/circuits will match.
ACTION: Refer to the following Circuit Color Code Chart for the correct color/circuit usage.
CIRCUIT COLOR CODE CHART
CIRCUIT FUNCTION - OLD COLOR* - SAE COLOR*
Trailer LH Turn/Stop - LG/O - Y
Trailer RH Turn/Stop - O/LB - DG
Trailer Brake Lamp From Controller - R/LG - R/LG
Trailer Electric Brakes Solenoid - BL/BR - DB
Trailer Back Up - BK/PK - R/Y
Trailer Ground - W - W
Trailer Running/Tail - W/R - BR/W
Trailer Power (Battery Charge) - Y - O
Trailer Brake Control Feed - R - R
Color Key& Abbreviations
BL-Blue
BK-Black
BR-Brown
DB-Dark Blue
DG-Dark Green
LB-Light Blue
LG-Light Green
O-Orange
P-Pink
R-Red
W-White
Y-Yellow
Here is a trailer tow relay wiring diagram
http://content.chiltonsonline.com/content/images/8828/images/88286w24.pdf
jlb
jlb
Detroit Mich
Thank you for the information my next question is what is confusing must have been rigged up before i got the truck the problem is one of my wires broke in the connector I have a red a red with a green strip a black and 2 yellows the 2 yellows were spliced together and ran into the the connector as one can it be ran like this tried to find a pigtail and was gonna splice it all back together but cant seem to find one.
OK, those colors are same as that EEC Power Relay in the Chilton
Check; RJM Injection Tech (by Ryan M (Fireguy50) @ http://www.rjminjectiontech.com/search?q=relay'>http://www.rjminjectiontech.com/search?q=relay
Ford EEC Relay pigtail $20.00, 4 female
http://www.rjminjectiontech.com/products/ford-eec-relay-con
FP Relay $20.00, 4 female
for other pigtails see (they seem to be del our Broncos now....):
Ford Motorcraft® (fordinstallersupport.com) - Wiring Pigtails Parts Catalog, Bronco/Ford truck & all Fords w/Ford part numbers & Illustrations (51MB pdf); 2005
http://www.fordinstallersupport.com/files/catalogs/wpt200.pdf
Ford Motorcraft® (fordtechservice.dealerconnection.com) Wiring Pigtails Kits Identification Guide, Bronco/Ford truck & all Fords w/Ford WPT & Long Version Part Numbers & Illustrations w/ Component Application, 2010
http://www.fordtechservice.dealerconnection.com/Renderers/ie/wiring/svg/images/connectorcatalog.pdf
OEHQ.com - Bronco/Ford truck Motorcraft connectors, pigtails, etc.
http://www.oehq.com/
Airtex® - Bronco/Ford truck connectors, switches (NSS, MLPS, etc.) ABS sensors, relays, fuel injectors & repair kits/FPRs, etc., blower motors/resistors, ignition modules, spark plug wires, rotos, caps, etc., EGR valves, water pumps, fuel pumps & fuel level sending units, voltage regulators, O2 sensors; etc.; many w/Ford part numbers
http://www.airtexproducts.com/
PICO (picocanada.com Canada) - Bronco/Ford truck electrical connectors, wire, switches, vacuum line connectors, terminals, blower motor resistor E7TZ-19A706-A
http://www.picocanada.com/
BobButtertone
