Fuel Pumps
fizz
Indiana
Is there a way to go to just one higher volume fuel pump instead of having two fuel pumps.
F
fizz
Indiana
Which fuel pump needs to be changed the one in the tank or the one in the upper frame rail or should both be replaced.
92broncomann
Coolidge, Arizona
It depends on which Pump is out. Either or can go, the upper one in much easier to change and the rear one is a bit harder.
have someone turn the key to the on position and check each pump. the ole ear in the filler neck will tell you if the rear one is working. and just feeling the one in the frame rail when you turn it on should tell you which one is working or not.
F
fizz
Indiana
Thanks that helped and it was the one in the tank. Since im replacing that one should i replace the other one to be on the safe side though.
92broncomann
Coolidge, Arizona
Only if you want to, if your not having any problems with it then why bother?? As the saying goes, dont fix it unless its bronken :) /emoticons/[email protected] 2x" width="20" height="20" />
79brnco
