fuel pump /sending unit
BOB MARLIN
Devore, CA
1990 5.0
I want to replace my fuel pump and my sending unit. Is there a brand to stay away from ?. There doesn't seem to be many options for getting both pieces together as an assembly, but that is what I would prefer. I don't mind spending a bit more for a better product if it available. What have others had good luck with ?.
Yo Bob,
Broncograveyard has the complete pump/sender kit, but doesn't identify the manufacturer. Contact them..
In other Bronco forums, most have bought from Broncgraveyard.
Ensure the connector is correct size.
See Note.
The larger surface-mounted connector (WPT454) was used until 1993.
Motech
Santa Cruz, CA:
I know this is late to the game, but you can still find complete units in Motorcraft brand, part number PFB4.
It will be expensive, as a list for over $600.00, but you can find them for less than $400.00. worth every penny too because they will not fail, and the inferior products are not much cheaper anyway.
HappenStance
