fuel pump change 1992 ford bronco
drtjmpr
i have a 1992 bronco with a 5.8 351and i need to change the fuel pump if anyone has any tips on how to do this the help would be great! i know its in the tank but thats about all i know so far.
yo!
2 ways to do it; (drain all fuel 1st) or cut access in floor pan to get to da pump & sender
one tip; buy a Ford Motorcraft pump
and read this;
drop tank Links:
Replacement in a 90 by rightofway
unfortunately, his pics are gone.
Replacement & Overview, In-Tank by Steve83
& Upgrade, 125LPH - 255LPH in a 96 by boss no need to upgrade but he has good info too!
then look in my site under;
Cut-out Panel Fabrication for Fuel Pump/Level Sender Replacement
there are a few Links there incl one good one by our pal Seabronc
Info on LINKS on Spring Lock Coupling Tool
esp. Scissors Type Instructions & Diagrams Source: by Steve83
this is for the fuel lines and also for replacing da fuel filter.
GL!
92NITE4x4
Oviedo Florida 32766
Yep, I have a 1' deep 20'' wide hole cut in my floor..get in get out..***** new metal down on top and put rubber mat back over..simple deal.
MUZZALL
Ellensburg WA
It may be a total bitch, drop the tank it's the clean proper way. If you get a couple of buddies to help it's not to difficult.
madmax
quakertown pa
If you do drop the tank while youve got it down look for anthing else that needs work that might be easier with it out. Can save time in the future that way
rcarm74
