Yup, it's got spark. It fires regularly when hit with a shot of either but dies immediately after burning it up (no joy using that method to prime the pump or pull fuel down like you can with the mechanical pumps)
Pedal to the floor makes no difference
Cleaned the IAC last wkend along with the throttle body.
Have been disconnecting the neg cable for a few hrs at a time when charging the battery.
No codes present with the KOEO (obviously can't do a KOER), well, a code 11 system pass but that's it
Occasionally it gets a trickle of fuel and will stumble or fire for a second but very rarely and never more than that.
It has 40lbs fuel pressure @ the rail and it has spark. I have no idea why this thing isn't firing. If there were an injector relay or something like that it would be easier but it seems like the injectors just aren't opening. It was running fine last wkend so there's just no way that all 8 have simultaneously clogged or failed. I know the injector pulse comes from the PCM, but *that* was replaced last month (along with the starter solenoid, neutral safety switch, coil, coil resistor, TFI, & distributor). It took a couple days to sort out the timing but it had been running fine, sat for a few days and now it won't fire again.
I'll tell ya, working on this thing is what convinced me to go out & buy another 79' instead of the 89' I was looking at
/emoticons/
[email protected] 2x" width="20" height="20" />
